IoT solutions for industrial equipment monitoring
Manage widely distributed industrial assets with one integrated IoT platform
Particle provides IoT devices, global connectivity, and software that helps industrial equipment manufacturers and distributors unlock new revenue streams, reduce operational costs, and differentiate their products.
Leading industrial equipment monitoring providers build with Particle
Avoid unplanned downtime
Get condition and performance data on machines and peripherals that makes it easy to predict system failures and prioritize maintenance calls to prevent unplanned outages and downtime.
Create new business models
Move from one-off machine sales to subscription-based business models that drive recurring revenue.
Easily replenish consumables
Track fuel, oil, and other consumables’ levels remotely so you never have machines sitting idle due to an empty tank.
How FieldIntell is making industrial equipment monitoring simple
Case Study
FieldIntell was working to build IoT-enabled solutions to help companies in capital-intensive industries like oil & gas, mining, and agriculture monitor and control their remote assets in real-time.
Their original IoT hardware provider failed to innovate, leaving FieldIntell scrambling to find another solution.
Particle's certified hardware, flexible operating system, global connectivity and robust fleet management capabilities helped FieldIntell rebuild their products quickly and deliver a superior end user experience.
Deploy IoT at scale so you never have to send someone to manually check a machine again
Get the data you need from any machinery
Build systems that reliably measure temperature, device states, consumable levels, location, pressure, vibration, and more.
Global connectivity that keeps industrial assets connected to the cloud
EtherLink, Particle’s cloud connectivity solution, ensures a reliable connection between devices and the cloud no matter where your industrial assets are.
A single, unified interface to your hardware
Particle’s Device OS abstracts the complexity away from traditional firmware development with hardware and feature-rich APIs that make it simple to write applications for any device.
Innovate and upgrade fearlessly
EtherFlash, our OTA update system, gives you compatibility verification, intelligent updates, and dynamic delivery so you can push OTA updates live in 30 seconds without bricking your devices.
Device management made easy
Use a scalable backend that lets you monitor and control all your devices with real-time event logs. remote diagnostics, and secure bi-directional commands.
"We’re relying on Particle as part of our future. We can expect them to keep us up to date with the latest developments in hardware and communications."
Why Particle
Accelerate your time to market
90% of Particle customers successfully deliver a product at scale within 12 months.
Get the freedom of an open platform
Everything about Particle is designed to be reprogrammable, reconfigurable, and API-driven.
Lower development costs
Particle abstracts away most of the complexity from IoT development, so you don't need to hire dozens of engineers to get started.
Use one integrated platform
Particle provides hardware, connectivity, security, and device/data management all in one platform.
Make upgrades easy with industry-leading over-the-air updates
Particle is pre-integrated with everything you need to reliably update your firmware. Add features, push fixes, and iterate quickly.
Tap into a powerful ecosystem
Particle connects you to leading design and integration partners, as well as a 10,000+ member community of IoT developers.
Own your data
Particle doesn't store any of your data. Keep all your data between you and your cloud provider with our open cloud APIs.
Protect your infrastructure with a secure-by-default platform
Protect your deployment with encryption and updated SOC II, GDPR, Privacy Shield, and CCPA compliance.
