One of our goals with the Spark Core and Spark OS was to abstract away the connectivity layer. When you’re running a distributed OS where some of your software runs on the device and some of your software runs in the cloud, you want the connection between the two to “just work”.
However, sometimes you don’t want everything to be automatic; you want to take control of the connection, so you can decide when the device should try to connect and when it shouldn’t. This is particularly helpful when you want your application code to start running immediately as soon as the device is powered, and the connectivity stuff can happen later on.
As of today, the Spark Core has three modes: AUTOMATIC
, SEMI_AUTOMATIC
, and MANUAL
. Let’s go through each of them in turn.
Automatic mode
The default mode of the Spark Core is “automatic mode”. This means that the Core will attempt to connect to Wi-Fi automatically. If you don’t explicitly define the connection mode, the Core will be running in automatic mode. This is identical to how the Spark Core has always worked up until now.
Behind the scenes, what’s running on the Spark Core looks something like this:
void main() {
// First, connect to the internet
Spark.connect();
// Then run the user-defined setup function
setup();
while (1) {
// Then alternate between processing messages to and from the Cloud...
Spark.process();
// ...and running the user-defined loop function
loop();
But the whole point of the automatic mode is you don’t really need to know that. The Wi-Fi connection just works. So let’s say your code looks like this:
// You don't have to add this, but if you want to be explicit:
SYSTEM_MODE(AUTOMATIC);
pinMode(D7, OUTPUT);
digitalWrite(D7, HIGH);
delay(500);
digitalWrite(D7, LOW);
delay(500);
What’s actually happening is that first we’re calling Spark.connect()
, which will connect the device to the Cloud. Once it’s connected, then your code will run, and your loop()
will alternate with Spark.process()
so that we can process incoming messages in something that resembles a background process. (Side note: Spark.process()
also runs during delays).
Ok, that’s all well and good, but what if I don’t know whether my Spark Core will have an internet connection? I still want my LED to blink. So now we’ve got:
Semi-automatic mode
// Insert firearm metaphor here
SYSTEM_MODE(SEMI_AUTOMATIC);
attachInterrupt(D0, connect, FALLING);
delay(500);
delay(500);
void connect() {
if (Spark.connected() == false) {
Spark.connect();
In this version of the code, when the Spark Core is plugged in, the LED will immediately start blinking. When a button attached to D0 is depressed (bringing DO to LOW
), Spark.connect()
will be called. If the Spark Core already has Wi-Fi credentials in memory, it will attempt to connect; otherwise, it will enter listening mode, and wait for your network name and password through the Spark mobile app or over USB.
The only main difference between SEMI_AUTOMATIC
mode and AUTOMATIC
mode is that Spark.connect()
is not called at the beginning of your code; you have to do that yourself. Let’s go deeper down the rabbit hole with:
Manual mode
The Spark Core’s manual mode puts everything in your hands. This mode gives you a lot of rope to hang yourself with, so tread cautiously.
Like SEMI_AUTOMATIC
mode, in MANUAL
mode you need to connect to the Cloud using Spark.connect()
yourself. However, in manual mode, the Core will not call Spark.process()
automatically; you have to call it yourself. So your code might look like this:
SYSTEM_MODE(MANUAL);
Spark.process();
delay(500);
Spark.process();
delay(500);
void connect() {
Spark.connect();
You must call Spark.process()
as frequently as possible to process messages from the Wi-Fi module. If you do not do so, you will encounter erratic behavior, such as:
- The Core losing its connection to the Cloud
- The Core breathing cyan when in fact it is not connected
- Long delays when a request is sent to the Core because the Core won’t respond until it’s processed the message
Sounds kinda terrible, right? Except this can be really useful when you’re writing code that is very sensitive to exact timing, and the Spark.process()
call might interrupt your sensitive code. By turning on MANUAL
mode, you can make sure that Spark.process()
is called when you want, and not when the processor is busy with a time-sensitive task.
As Stan Lee once said: with great power comes great responsibility. Go forth and control the connection. Be careful. Good luck.
